Front End Issues With An H1
Re: Front End Issues With An H1
[quote name='gstacky' date='30 June 2010 - 03:33 PM' timestamp='1277908392' post='18706']
Found the problem today guys, needs a pitman arm bad, any place other than the dealership to get one of these?
Your Local parts store should be able to get ahold of it!! Ask for the MOOG part!
[quote name='gstacky' date='02 July 2010 - 01:34 PM' timestamp='1278092063' post='18767']
Hey Kev
You wouldn't happen to have a part number for the Moog pitman arm would you? We are having a tough time locating one. They did find a listing for a 97, ours is a 98, any difference that you know of?
Any help is appreciated, I know the dealer can get one, but it is a week away.
From flashoffroad.com
Updated Pitman arm Napa 268-1665 (note, I do not know if this is the updated one!)
I will have three in stock this week.
www.crazycanucks4x4.com
Sorry D, a little advertising to help a fellow out
Kurt
Post by Kurt »
I had bad luck with the NAPA/Generic parts for steering components [they are often the older non-problem sover models]
The Factory part numbers for the "Moog problem solver" is:
AM General part numbers:
6011300 ASSEMBLY, PITMAN ARM [around $65 USD]
5745558 KIT, IDLER ARM [around $116 USD]
The kits have Moog problem solver stamped on them and come with the nuts and hardware.
If a local Hummer dealer is marking them up really high, you can order them from Lynch or Tustin Hummer in the US, and you should have it at near wholesale [above prices] no tax, plus, free ground shipping to the US and Canada if you don't mind waiting up to a business week.
I'm finding pitman and idler arms are a wear/maintenance item especially if you daily drive your H1 and go wheeling a lot, especially with lift kits and larger tires. One of my friends running 40" tires and a lift goes through a set a year.
[quote name='Roy' date='02 July 2010 - 03:16 PM' timestamp='1278098180' post='18769']
Sorry D, a little advertizing to help a fellow out
you're a sponsor.. go ahead Roy!!
duncanpa
Post by duncanpa »
Roy...as a sponsor, you can talk up the forum all you want....we all need what you got anyways...Hummer Parts and the knowldege to know how to get and install them..... <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
[quote name='gstacky' date='30 June 2010 - 10:33 AM' timestamp='1277908392' post='18706']
Did you ever get the parts you needed?,Have 3 pitmans in stock,"problem solvers" all from AMG.Need anything else? All items on my site are in stock!!
[quote name='Roy' date='21 July 2010 - 06:19 AM' timestamp='1279711179' post='19555']
GOOD NEWS FOR HUMMER FANS IN CANADA...."WE HAVE IN STOCK HUMMER PARTS IN CANADA" .....ITS ABOUT TIME WE HAVE A REAL DEALER IN CANADA THAT CARRYSSSSSSSSSSSSSSSSSSSSSSSS PARTS...THANKS ROY <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
