Winch tester Needed
Re: Winch tester Needed
[quote name='Archngel' timestamp='1293512466' post='23902']
Can any of them be fitted on a H3 without major transfo, I like the permanent behind bumper setting, but if a removable setting like on the H2, I'b interrested.
Can be done like an H2 as long as you have the receiver on your truck.Have to see what the Kev man says for this.
Here is the link for the front mounted receiver to allow use of the winch on either the front or the rear of the H3 using a standard winch carrier.
http://www.drawtite-hitches.com/products/65047
In my opinion, you can mount it either way, up or down. I would personally install it upside down according to the pics in the link as this will put the receiver and winch higher and thus having less of an effect on approach angle. Also it is easier to cut a clean hole in plastic than in aluminum.
Or you could always buy 2 winches and install one on the front and one of the rear permanently!!! <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Winches are at the border and will cross on the 10th or 11th.
Bringing in a lot of new stuff.Three new suppliers and more AMG. stuff.
All adding up to more than 10g more inventory . <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... >/ohmy.gif' class='bbc_emoticon' alt=':o' /> <img src='http://www.canadianhummerclub.com/forum ... >/ohmy.gif' class='bbc_emoticon' alt=':o' /> <img src='http://www.canadianhummerclub.com/forum ... >/cool.gif' class='bbc_emoticon' alt='8)' />
Holy crap....can't wait to see what goodies you have now...
