ScanGuage II
Re: ScanGuage II
This sounds Cool, I believe TOM has one installed in his Truck....
- paulg
Re: ScanGuage II
I got one from a supplier in Ontario, was a good price and free shipping, Not as good as JL's thou...but not a site sponsor, so PM me if you want the name.
My Truck is almost back together so I will be putting it in onces its running, but right now I have it installed in the wife's forester and its pretty cool, tons of real time sensor info that the factory gauges dont even show!
I orderd mine with an extra cable, so I am going to setup both the H1 and Subaru so I can just pop it in and connect it, and the cable stays nicely hidden.
[left]2001 black HMCS
3" bodylift
Heath Programed ECU
Remote PMD
CMGS water\meth injection
Rear head cooling kit
Scangage II
Boost, EGT, Temp gauges.
Dynamat extreme
dual optima red tops
Straight piped exhaust[/left]
3" bodylift
Heath Programed ECU
Remote PMD
Scangage II
Dynamat extreme
Re: ScanGuage II
need to see your photos Paul when she is all done...
Re: ScanGuage II
I got the scan gauge from Jarrett, I LOVE it and it works with a 96!!! I highly recommend.. lots of great information!
just one question to those that have one... how do you set it up for the two fuel tanks??
Re: ScanGuage II
i installed it on top of my inclinometer and ran the cable under the panel under the steering column and up behind the TAC and clock and popped it out at the top and plugged it in behind. The cable to the right is from the GPS that will be replaced with my in Dash foldout one.
- JL
Re: ScanGuage II
Nice! Looks good installed... Hope you're as happy with it as I am with mine!!
Still looking into the fuel tank question but I will let you know...
Re: ScanGuage II
thanks Jarrett
As for it looking good, thanks for being kinda, my dash is a bit busy and messy currently, I have a ton of new stuff to install and where I installed it now might not end up being the final location..so much to do, never enough time to do it all...
I am very happy, for sure! I think everyone should get one!!! especially H1 owners, lots of get info in there that we do not have factory gauges to tell us. The H2 and H3 have a lot of these features built in from Factory but not the H1s...A great help!
