[quote name='Indy' timestamp='1322244840' post='33054']
Wouldn't this make the water really hot, especially if not in use, since there will always be water trapped in the lines. Also, spraying hot water on an ice cold windshield might not be the best idea...but then again I might be wrong. Just a thought. For me, antifreeze Windshield washer fluid is the best and safest way to go and a cover for the windshield while it is parked outside to prevent it from freezing.
These generally only heat the fluid when you activate the sprayer, any remaining fluid would just cool down after. As for spraying on the cold glass, you can go to a certain temperature, not that I know off hand what that is, but I'd have to presume these are below that temp. At least I would hope anyway. <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' />
Heated Windshield Washer Fluid
- Gadgets
Re: Heated Windshield Washer Fluid
<p class="bbc_center">
- Indy
You just have to love the heated windshields of the H1 when going through winter. Too bad the H2 doesn`t come with one. It would seem to be a useful option and I can`t imaging that it would have cost GM that much too produce one. That would make life a lot easier in the winter.
Ferrari Mondial 3.2 Cabriolet
Jeep Grand Cherokee 5.7 Hemi
99 HUMMER H1 HMCS / bright white / P400 6.5TD / heavily modded - sold
VIPER RT10 GenII / silver - graphite stripes - sold
FJ Cruiser / sun fusion yellow / "C" package- sold
HUMMER H2 / yellow / Adv. package / 4" lift / 37" STT - sold
Plymouth P R O W L E R / red - sold
Corvette C5 / Millennium Yellow / 6M - sold
Corvette C5 / Nassau Blue / 6M - sold
J E E P ZJ / 7" lift / white / 35" Cooper STT - sold
J E E P TJ / 7" lift /chillipepper red / 37" MTR - sold
Mustang GT 4.6 / black / 5M - sold
[quote name='Indy' timestamp='1322352347' post='33093']
I agree! It is way more effective than the blow hot air version used by all manufacturers. That and the fact that an H1 that didn't have the heated windshield option didn't need them anyways...you couldn't see enough out of the windshield to be able to drive the truck anyways!!! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
