Backup camera and integration to OEM NAV
kevin
Re: Backup camera and integration to OEM NAV
Post by kevin »
this is the newer version of what I got from Nav-tv.. Very excellent!
Did you get hooked up HumPlum?
kevin
Post by kevin »
I'm just wondering to order camera 2 or 3
kevin
Post by kevin »
Getting it hooked up Friday. Does the dash around the stereo come off easy?
You actually need to take out the center console to get to the bottom two screws of the center dash, don't pul or bend, it will break!
Take your time and remove the center console, the gear shift etc..this will make your life simple and nothing will break, it took a long time for me to figure this out and a lot of forum searching..even my dealership was not sure.
Anywasy once you take out the center console, the center dash will come off easy and the stereo comes out and you have easy access to do the hook up and to tuck this all away. A bit of advice, zip tie the control box down so it does not rattle around, especially if you off road.
Let me know if you need anymore help.
Derek
kevin
Post by kevin »
Had it installed but now when I turn the key off, the radio is still on but my screen is black, no picture. Is this normal or did buddy screw up the install.
I don't have that issue...maybe he d the wrong wires?
