So far, a better turn out, 4 Canadian trucks and time still left to register.
Trying to get Kevin to bring to H2 out, Hopefully Markus,Chris, Andrea,maybe Liam,Paul (3 for 1 optical) will register soon.
There will be 2-3 trailered trucks going down ,so,if you did break, we can still get you home.
Rubber Duck Anniversary Off Roading Tenn.
Re: Rubber Duck Anniversary Off Roading Tenn.
- Sub
Im still ok so far for oct... will se what happens
Event is full according to RD website, last check over 60 trucks. Check directly at RubberDuck for openings 513-899-1735
So what day are we heading down to Tenn.?
So far only 4 trucks, Roy,TC,Sub, and Canada1
I am more than likely heading down on Tuesday afternoon ,maybe early Wed., depending on if there is interest in a convoy.
Normal driving is 4 hrs per stop.( truck fuel stop for trailering trucks ) H1's can do an 8 hr run before fuel, but lets play safe just in case
Fueling stops....
full when leaving KW area or equivilent distance
Bowling Green Oh 4 hr 3 min
Lexington Ky 3 hr 55 min
Clinton Tn 2 hr 24 min
Hotel 24 min
With stops an estimated 12-13 Hour road trip
If heading out on the 22nd, we should be on the road before 7am.
Fueling stops....
Hotel 24 min
ONLY 4 trucks for this event !!!! Damm .....this will not happen again in a LONG time !!!! Maybe never!!!!!!
- Sub
i will join the convoy if we launch around 8am...i dont have any cancelation changes, i am only sencitive to my passport, which i sent in for renewwal last week and i think it should be back by then, i will be trailerin also my 04 and hopefully no issues so far. Canada 1 , are you in ontario?
- Sub
hotel booked.looking forward to meet my oldy grumpies Hummers soon!
Do not run a dealer plate across the border, could get interesting ,
if driving that ford, put some tires on the front end.
Tentitively,
we will be leaving London around 7 am. --12 hrs driving with stops.
May be heading out the night before if the other 2 are still in Florida.
Tentitively,
- canadah1
I am planning to come back from Florida then go on the Wednesday 22Oct14 to the event. Need to do some work before but that might change.
Sub, I live in Newmarket so would be leaving 4:30am or so to meet up in London if the convoy is a go. If no convoy I would probably head down through Buffalo. Will keep you guys posted if any change in plans.
I spoke to Travis and he is now maxed out at 70 trucks and 160 people approx. "This is going to be crazy" I believe were his words.
Cheers,
Tom
Cheers,
Tom
Ya 70 trucks in the back end of the hotel.
This will be a blast.
Its not just the trucks, but the trailers and rigs that pulled them as well.
It looks like the food places may be a bit busy a couple of nights.
I know there is one or two unregistered trucks that may come as well.
Travis also mentioned about some LIVE bluegrass as a good possiblity.
