Replaced battery terminals
citiboy
Re: Replaced battery terminals
Post by citiboy »
[quote="Sugarphreak"]
Any more details on that aux input, I really need one in my truck and that is super clean!
SP, here's the link <a href="http://www.kawal.net/auxinput.htm#Alter ... rnative</a> (choose alternative 2).
The only thing i did was cut the xm input and output wire from the radio connector and connected the aux. jack that i made (as per instructions) in series. This way, i can listen to xm then if i want to listen to any external audio, i just plugged in the 3.5mm audio cable and it will automatically interrupt the xm.
You can buy this guy kit (no affiliation whatsoever) for easy install but i went on the cheap route. Works ok so far.
<div> </div>
