[quote author=HummBob link=topic=481.msg2233#msg2233 date=1212479080]
I dunno?? Try GooGleing!!!
I know you can add an inline one...not sure if it is worth it or not.
Fuel Filter
Re: Fuel Filter
I have a part number so there might be a filter. Wix filter number 33129. If this is the case it is tucked between the gas tank and the crossmember behind the t-case. You'll need to remove the t-case skidplate and be very patient, access is VERY limited!! BTW, pay careful attention to which hose connects where since they will connect in either position and if you connect them wrong, bye bye power!
Kevin
Kevin
Re: Fuel Filter
[quote author=whitehumh2 link=topic=481.msg2288#msg2288 date=1212586630]
Kevin
that would not be good....
Thanks Kevin for the info.
Kevin
- HummBob
Re: Fuel Filter
What YEAR?? I think that's ONLY 2003???
Re: Fuel Filter
[quote author=HummBob link=topic=481.msg2318#msg2318 date=1212652937]
mine is like yours Bob, a 2005
- BrokenPlay
Re: Fuel Filter
I have not looked into this, but when I had my 1997 Dodge Ram 1500...the fuel filter was in the tank. It was changeable, BUT, you had to drop the fuel tank to do so. I would guess that this may be the same idea.
