Check the parts out..
www.mcmaster.com
part #
5478K141
5478K711
nylon tubing can be various colours, or, can purchase ss lines , will check ctc out later for a 6" ss hose(water flex hose)
New Quick Disconnects for H1s with CTIS
- dbot
Re: New Quick Disconnects for H1s with CTIS
Forget about machining the elbow for the schrader valve, You don't need it, just make up a fitting that has a valve on it if you need one in an emergency you can just plug it into the line on the wheel end.
These fittings totally disconnect and seal themselves so you don't need to unbolt them from the hub with a tire change.
To save some money mcmaster also has plastic fittings that do the same. They are a lot less money.
[quote author=ROYS link=topic=705.msg5187#msg5187 date=1225845472]
www.mcmaster.com
part #
5478K141
5478K711
[/quo
VERY GOOD ...THANKS
www.mcmaster.com
part #
5478K141
5478K711
[/quo
VERY GOOD ...THANKS
[quote author=dbot link=topic=705.msg5199#msg5199 date=1225851941]
INFO INFO INFO .................THAT IS ALL WE NEED......THANKS
price update...you will love this.
On your order placed with McMaster-Carr, you ordered 4 each of our part numbers 5478K711 & 5478K141 (tube couplings). The Canadian government has imposed a 242% anti-dumping duty on certain brass fittings. The duty applies to these items. We removed these lines from your order due to the inflated cost to import these items to you. If you still want to buy these from us please let us know and provide us your UPS or FedEx collect number so that the applicable duties will be charged to you as the importer of record.
Kent Madey
McMaster-Carr Supply Company
This would add an additional $43 to a wheel (47.50 + 43). Have to check for Canadian parts.......
Kent Madey
ROY, SHIP TO MY US WAREHOUSE I WILL CONTACT YOU
- Injunfarian
- CHC President
thanks for the info <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
