[quote name='HoleHog' date='29 August 2010 - 12:21 PM' timestamp='1283106091' post='20542']
Interesting article here... Steering problem applies to Corvettes but sounds similar to your problem. H3 recalss mentioned might be applied to your truck too...worth reading anyways:
http://www.autoevolu...ttes-20120.html
That sounds dead bang.... It sounds like it's in the stabilitrac system and not the steering. If the system is faulty - could cause one side or the other to brake without cause.
Print the article and take it in to them and state that this is a serious safety concern and has been noted to you - you are now responsible by turning me away if anything goes wrong. Skip the drones in the Bay and ask for the service manager and only deal with him now and say you have a lemon that Shaw sold you and is now giving a constant run around...
Alberta September Run
- Khamul
Re: Alberta September Run
- Sugarphreak
Yeah there is no way they can turn me away, I know how to duplicate it exactly now.
Basically if I am making a left turn, the longer I turn in one direction (either left or right) the more pressure builds up to turn the truck the other direction... so much so that if I let go of the wheel spins and throws the truck out of control; it will go past the straight position and in the opposite direction you are turning... now I can man-handle the damn thing to control it, but if I have to take one of those 360 degree turn off ramps, I am pretty much screwed.
I don't understand how stabilitrac would influence the steering though, it doesn't feel like one side is braking.
- Sugarphreak
Just test drove it with stabilitrak and TC turned off... no change, it fights like crazy.
It has basically become reverse power steering, I think it needs to be flat bedded to the dealer because it is way too dangerous to drive like this.
- JL
I wonder.. have you tried engaging/disengaging the front locker? It sounds like severe understeer which you would experience if the front wheels were locked on dry pavement..
- Sugarphreak
[quote name='JL' date='29 August 2010 - 09:09 PM' timestamp='1283130599' post='20555']
If it was engaged it would skip the tires on sharp corners, the wheel movement is actually aligned and smooth... just the steering is screwy.
- JL
So weird... well all I know for sure man is be safe and get it on a flat bed if you think it need it!!
- Khamul
It may just feel like it is in the steering.....
When turning left like you say... if the Stabilitrak engages the brake on the right front wheel only... It would feel like the steering is pulling you back in the opposite direction.
It sounds like it's confused and doesn't like it when you turn so it compensates for it...
I may be wrong... but that's what it sounds like....
- Mike_Luchia
Looks like the wife and I are going to be able to make this run. See you there <img src='http://www.canadianhummerclub.com/forum ... /smile.gif' class='bbc_emoticon' alt=':)' />
Mike
Blackberry PIN 311E1F04
- Khamul
[quote name='Mike' date='30 August 2010 - 08:03 AM' timestamp='1283177039' post='20565']
Great to have you along!
- karlairey
Sweet!
Have you been offroading? If you have, where is your favorite spots? It'll be cool to have another Yellow Truck out there
Sweet!
