VIBRATION
Sub
Re: VIBRATION
Post by Sub »
[quote name='ride2099' timestamp='1334355668' post='36166']
hey guy issues fix !! my rims was totally unbalanced !! the 4 rims need balance and I got my front right tire to change is not round anymore so making my vibration !! so today i order new tire and new rims hahaha
(4) Yokohama geolandar m/t 38x13.50r17
(4) eagle alloy 027 Black 17x9
Cant wait to put on the truck !! I also need to replace (2) Upper ball joint so ball joint and new rims tire its a 3500$ repair hhahahaha
i would say its still a cheap fix estimate, because you still must do aligment due to ball joints and wheels being replaced as well as do your Hub bearing seals because most of them might be leaking bad due to constant uneven rotation stress and your hood might need readjustment to void hood vibration issue- so 4000 is not to far lol
ride2099
Re: VIBRATION
Post by ride2099 »
[quote name='Subprimer' timestamp='1334370416' post='36168']
Wow your such a beast !!! my left front seal need to be change is not that bad but I want the truck clean so monday I go to garage changing (2) Upper ball joint, geared hub input seal and transfer case safety cable !!! and also aligment, I got all my parts at hummerpartsguys for near 400$ and maybe 600$ for the job
HUMMER H1 SUT 1998 6.5TD
