Finally getting some TLC
- Injunfarian
- CHC President
Re: Finally getting some TLC
oh wow luckily no blood but yes she will make you remember her
Still ripping and tearing...
This was one of the rear suspension bolts that took a bit to get out.
Inspection of a part... ever lose steering?
you were lucky
Look real close...after clicking on picture
the lower shock bolt was seizes bad.. replaced with a better one.
Yes that is a crack in the pitman arm,also the stem is bent ,which marked up the inner hole on the center drag link. Replacement of both parts
Most parts are ready for paint once the rain stops...Then ,put it together and do an alignment
- Injunfarian
- CHC President
Oh wow yes she was in rough shape, she did have a very bad death wobble on her before she was parked glad I had parked it when I did by the looks of it.
Sorry, had to take some time off this project and get the really OFF ROAD vessels ready for the season. Front end is now completed, Starting to reassemble rear suspension.
- Injunfarian
- CHC President
Looks AWESOME thank you for the update.
I have some heated bullet proof windshields and some 24bolt 2pc wheels I need to drop off to you.
Wow, ita looking great,
I love when parts are all new, it's pretty well looks restored.
- Injunfarian
- CHC President
Yes it does look good.. Once I get it back I want to pull the rear bumper and sand blast/paint it as well as the front brush bar and winch mount(likely removing removing the winch and keeping it out until its either rebuilt or I get a new one since the old one is inoperable and in need of some TLC.
