Front Licence Plate Ontario
Hesh
Re: Front Licence Plate Ontario
Post by Hesh »
For any of the H1 owners on here looking for another solution to mounting their plates without it hanging below the winch fairlead, or blocking the fairlead, this is what I have done, using the grill guard and a couple of KC Hilite Mounting solutions:
Basically, after having lost 3 front plates in a month, from having been mounted on the bracket that hangs below the fairlead (as still seen in that photo), I got fed up. The brackets I used cost less than $30, and were able to be used for grill-guards tubing that was anywhere from 1-2.5" (iirc). KC Hilite part number was 7307, but I know that PIAA has a couple solutions for grill guard mounting solutions for tubing anywhere from 1.25" all the way to 3" like the ones below
Image Image
great idea Hesh...
Archngel
Post by Archngel »
Just so that we are aware.
is your vehicle a target
<img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
