[quote name='dwaxman1' date='11 March 2010 - 11:05 PM' timestamp='1268366722' post='14412']
Anyone know what the laws are about carrying Jerry Cans on your Truck with Fuel in them?? is there a law? I don't just mean in Ontario but anywhere??
there are regulations regarding this from transport canada.
french http://www.tc.gc.ca/fra/tmd/bulletin-au ... 04-306.htm
english http://www.tc.gc.ca/eng/tdg/newsletter-fall2004-306.htm
Military warehouse
- Archngel
Re: Military warehouse
- Archngel
[quote name='dwaxman1' date='15 March 2010 - 09:49 PM' timestamp='1268707777' post='14638']
I need 3 jerry cans for Fuel, one for Water...forget the ammo boxes..
thanks sir
Will get the 3 Jerrycans for fuel,, so far no jerrycan for water yet, they may receive some by then ( Rally )they dont know. Will keep you posted. Will pick up fuel ones this week.
Arch
thanks sir
Arch
[quote name='Archngel' date='16 March 2010 - 07:17 PM' timestamp='1268785020' post='14677']
Arch
make sure derek give you gaz money <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
Arch
- Archngel
[quote name='T.C.' date='16 March 2010 - 07:41 PM' timestamp='1268786462' post='14681']
Arent we all familly,, Who would try to screw over brother and sister ( Well I may know a few, but that beside the point ) All innocent until proven guilty. But if it goes bad I have my way to get what I want
mouahahahahah
[quote name='Archngel' date='15 March 2010 - 11:28 PM' timestamp='1268710083' post='14640']
too much to read.. <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' /> I will take the fine if need be..
[quote name='Archngel' date='16 March 2010 - 09:18 PM' timestamp='1268788726' post='14689']
mouahahahahah
I will of course by you a beer or two.. <img src='http://www.canadianhummerclub.com/forum ... /wavey.gif' class='bbc_emoticon' alt=':wavey:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
as for Tony.. <img src='http://www.canadianhummerclub.com/forum ... >/kiss.gif' class='bbc_emoticon' alt=':-*' /> <img src='http://www.canadianhummerclub.com/forum ... n_evil.gif' class='bbc_emoticon' alt=':evil:' /> <img src='http://www.canadianhummerclub.com/forum ... n_evil.gif' class='bbc_emoticon' alt=':evil:' />
- Archngel
[quote name='dwaxman1' date='16 March 2010 - 08:33 PM' timestamp='1268789623' post='14690']
For sure its not really easy to understantd gouvernment litterature. Here is the short version. When I have the time Ill get the french done.
Basically for the Jerrycan 20L it says
Gasoline UN 1203
30L or less, No spec when the conditions for Limited quantity are met.
Conditions of Limited Quantity:
1.17 Limited Quantities Exemption
SOR/2008-34
(1) A quantity of dangerous goods, other than explosives, is a limited quantity if
A. the dangerous goods are in one or more means of containment designed, constructed, filled, closed, secured and maintained so that under normal conditions of transport, including handling, there will be no accidental release of the dangerous goods that could endanger public safety; and
B. each means of containment has a gross mass less than or equal to 30 kg and the dangerous goods
(i) if a solid, have a mass that is less than or equal to the number shown for them in column 6 of Schedule 1 when that number is expressed in kilograms,
(ii) if a liquid, have a volume that is less than or equal to the number shown for them in column 6 of Schedule 1 when that number is expressed in litres, or
(iii) if a gas, including a gas in a liquefied form, are contained in one or more means of containment each of which has a capacity less than or equal to the number shown for them in column 6 of Schedule 1 when that number is expressed in litres.
(2) Part 3 (Documentation), Part 4 (Dangerous Goods Safety Marks), Part 5 (Means of Containment), Part 6 (Training), Part 7 (Emergency Response Assistance Plan) and Part 8 (Accidental Release and Imminent Accidental Release Report Requirements) do not apply to the handling, offering for transport or transporting of limited quantities of dangerous goods on a road vehicle, a railway vehicle or a ship on a domestic voyage if
A. each means of containment is marked on one side, other than a side on which it is intended to rest or to be stacked during transport, with
(i) the words “Limited Quantity” or “quantité limitée”,
(ii) the abbreviation “Ltd. Qty.” or “quant. ltée”, or
(iii) the words “Consumer Commodity” or “bien de consommation”; and
B. the words or abbreviations are visible and legible and displayed on a contrasting background.
SOR/2008-34
(3) When a limited quantity of dangerous goods is in a means of containment that is inside another means of containment, the inner means of containment is not required to be marked if
A. the gross mass of the outer means of containment is less than or equal to 30 kg;
B. the outer means of containment is not intended to be opened during transport; and
C. the outer means of containment is marked, legibly andvisibly on a contrasting background, with
(iii) the words “Consumer Commodity” or “bien de consommation”.
(4) Instead of the marking required in paragraphs (2)(a) and (3)(c), the means of containment may have displayed on it the UN numbers of the limited quantities of dangerous goods preceded by the letters “UN” placed within a diamond-shaped mark. The line forming the diamond shaped mark must be black with a width of at least 2 mm. If the dangerous goods have different UN numbers, then the mark must be large enough to include each UN number but in any case each side must not be less than 50 mm. The UN numbers and letters must be at least 6 mm high. The line, UN numbers and letters must be on a contrasting background.
Gasoline UN 1203
SOR/2008-34
SOR/2008-34
- shotgun-cam
Oh Boy Legalize just needs 3 pages of really fine print <img src='http://www.canadianhummerclub.com/forum ... ey-013.gif' class='bbc_emoticon' alt=':wtf:' /> Reminds me of regulations on alcohol storage tank and port at printing comp.
[quote name='Archngel' date='16 March 2010 - 08:18 PM' timestamp='1268788726' post='14689']
mouahahahahah
<img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> GOOD ONE
[quote name='dwaxman1' date='16 March 2010 - 08:37 PM' timestamp='1268789865' post='14691']
<img src='http://www.canadianhummerclub.com/forum ... prised.gif' class='bbc_emoticon' alt=':eek:' /> <img src='http://www.canadianhummerclub.com/forum ... on_cry.gif' class='bbc_emoticon' alt='
' /> <img src='http://www.canadianhummerclub.com/forum ... /laugh.gif' class='bbc_emoticon' alt=':lol:' />
