Duramax Conversion
hameee@hotmail.com
Re: Duramax Conversion
Post by hameee@hotmail.com »
[quote name='Polar Bear' timestamp='1295833854' post='24471']
How much mileage does your H1 have?? If the flanges are moving up and down the same amount front and rear, I would encourage you to pull the axle shafts (use a slide hammer) the splines may be getting worn and therefore allowing extra movement. Also your axle shaft bearing is probably weak and should be replaced. It is also possible that your Diff may need a new center...if so install front and rear ARB Air Lockers...they are very strong and will give you way more traction!!
Hope this helps!!
Sounds good, Thanks
steve... I was able to get my hands on a 2006 complete Alpha parts book, not sure if it will help you or not..let me know and I can share ;-)
hameee@hotmail.com
[quote name='dwaxman1' timestamp='1295892157' post='24516']
That's cool, is it digital or paper? If would love a copy of it all if it's able to emailed to me, Thanks, Steve
hameee@hotmail.com
T's alive,
I scrapped the harness and made it user friendly, then started it to make sure everything was still working fine and to run the codes.
Check out the video
Last edited by hameee@hotmail.com on Tue Jan 25, 2011 9:28 pm, edited 1 time in total.
Sounding Good!!!
But Quick Question...Are you sure the body will clear the exhaust??? That sure looks like WAY more pipe than will clear the dog house and the floor cut-out!!!
[quote name='hameee' timestamp='1295924395' post='24562']
Here you go with a special thanks to David at Hummer Parts Guy, hope it helps you....sorry to big to email...
2006 H1 Alpha Parts Manual
By the way... lots of cool accessories at the end of it... LOTS of VERY COOL HUMMER GEAR!
hameee@hotmail.com
Not positive, but that I can fix in 10 min. If it's to tight I'll cut and reweld the down pipe to make it fit. The main thing that I'm worried about is the heads fitting between the dog house verticals. So far on this swap I have learned that there's not much room for error, this is a tight fit.
Steve, you have a photo of what your truck looked like before you began this???inside and out??
hameee@hotmail.com
[quote name='dwaxman1' timestamp='1296008535' post='24640']
Thanks a lot, this is great to have.
Steve
hameee@hotmail.com
[quote name='dwaxman1' timestamp='1296009224' post='24644']
Somewhere, do you what me to post them?
