Sluggish Acceleration Hummer H1 6.5 non turbo Diesel
Re: Sluggish Acceleration Hummer H1 6.5 non turbo Diesel
Nice to see the diagnosis was correct. Shifting issue resolved with the new TPS as well?
Skenth
Post by Skenth »
No..it's shifting fine w/o tps Replacement. Maybe it was all related to the failing pump.
Sonny Kenth
You had a new TPS install onto old pump, Phil would have transferred it to the new one.
As long as it runs great, problem(s) solved
Skenth
Post by Skenth »
I'm assuming he transferred the new one ontothe new pump. I'll check w him.
Sonny Kenth
