[quote name='Sugarphreak' timestamp='1322261255' post='33063']
Just brokered a BIG package of H3T parts into Canada today..... <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' />
Details? <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' />
Sugarphreak's H3T
- Sugarphreak
Re: Sugarphreak's H3T
Merry Christmas to me <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
Box arrived today...
The first peak inside!
Looks like the H3T will be getting some new shocks... and rear leafs <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
But wait.... There is more!
<img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' /> <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
- Khamul
Pretty!
- 08SolarFlareH3
More! <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' />
- johnnyspikesH3
Did RS 9000 SHOCKS COME WITH THE REMOTE SETTING BUTTONS FOR IN CAB ? Was it in the kit ? If sooo.. That's just pure icing on everything . Sweet sweet fun . <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
- Sugarphreak
[quote name='johnnyspikesH3' timestamp='1322877134' post='33223']
[/quote] I know the 9000xl's are compatible with the "MyRide" wireless kit as well, but I didn't really want to get into installing an air compressor and running lines to each shock. Just seems like more things to go wrong.
Lots and lots of threads like this out there: people running into issues with the system bleeding off air.
http://www.vehicross.info/forums/showthread.php?t=20099
There are the XL's up close, just a dial for now.
- johnnyspikesH3
Wow i never knew about that many issues . I read awhile back that if you do a lot of Off Roading you need to secure and locate the air lines good . Never knew about this many issues . You would think Rancho with their R@D would fine tuned it a lot better . Yup stick with the Manual dial .
- Sugarphreak
[quote name='johnnyspikesH3' timestamp='1322920429' post='33229']
It is a really cool idea, but I literally found forum after forum of people running into problems.
From what I have been reading, most guys pick a "sleep number" and leave it there; most of the Toyota and Jeep guys have been setting them up around the #3 position while the Dodge guys run them at closer to #6.
My truck is somewhere in the middle for weight, so I will probably start them off with #4 (as I use the truck more for off-road than on these days) and see how that goes. I may adjust them up or down for runs as well if it isn't too much of a PITA, also if I do road trips or get materials for my house I may run them a lot higher.
- Sugarphreak
Got home, started working on the truck tonight. Went like this.
Step #1
Jack up truck, remove front tires..... Check!
Step #2
Remove front skid plates....
....must remove front skid plates, one bolt left to go; oh crap, seized Allen bolt not... coming... off... ahhh crap it is stripping. Try to fix... no, stupid BOLT!! WHY WON'T YOU COME OFF!!!! *BANG BANG BANG* <img src='http://www.canadianhummerclub.com/forum ... ey-055.gif' class='bbc_emoticon' alt=':curse:' /> NNoooooooOOOOOoooo. Come off you retarded bolt!!! NNNOOOooooooooo... <img src='http://www.canadianhummerclub.com/forum ... rassed.gif' class='bbc_emoticon' alt=':-[' /> ok, calm down... get drill bit, and drill out bolt. DRILLLLLLLLLLLLLLLLLLLLLL... hmmm, this is making a lot of noise, what time is it.... AKKK 10:30pm!!! <img src='http://www.canadianhummerclub.com/forum ... n_evil.gif' class='bbc_emoticon' alt=':evil:' />
Ok, will tackle step #2 tomorrow
Step #1
Step #2
- JL
LOL You are a brave man to tackle this in the garage!!
Now I just though of something... will it be low enough when completed to back out of the garage when you are done... could be close!!
