Page 1 of 1
torsion bar keys
Posted: Sun Aug 30, 2009 10:54 am
by rogco
well i cant decide either to put a 6inch lift on or just new keys and run 37s . i think i want the torsion bars and 37s first to but just wondering what you guys run and do the 37 rub at all off road or towing , and i know it matter a bit with rims but if i stay with stock rims would it rub easy or when towing a heavy load and i dont have the air bag set up i have the coil springs .. thanks for any info
Re: torsion bar keys
Posted: Sun Aug 30, 2009 3:08 pm
by brianwidahl
i run 37s on my 2003 h2 with keys and coil spacers.
i also have a 2" wheel spacers because they used to rub on the inside (sway bar)
no rub at all even at full articulation.
brian
Posted: Sun Aug 30, 2009 6:22 pm
by normsadler
I put 37"x12.5" Pro Comps on the stock chromed rims and I get some rub on the sway bar when turning full left. Off roading I noticed a little rub on the plastic inside the fender wells, but nothing major. I love the look of the new tires!
Posted: Mon Aug 31, 2009 2:23 pm
by dwaxman1
I got a new set of keys and cranked my keys, I run 37X12.5x17 Goodyear MTRs, no rubbing at all, no spacer in my 2005 H2
Posted: Thu Sep 03, 2009 9:32 pm
by rogco
thanks for the info , so if i go with aftermarket rims then it should move the tire away from rubbing on the sway bar then
Posted: Thu Sep 03, 2009 9:35 pm
by brianwidahl
you betcha it doesn't rub by much. it may not even rub at all if you go 12.5 wide instead of 13.5 wide
Posted: Fri Sep 04, 2009 1:28 am
by rogco
ya im putting in cognito leveling kit and with there beefed up pitman joints and also installing there double shock kit with the fabtech stronger tierods , i think it should go nice with 37's . . what you guy recomend for a good off road tire but gets good highways miles out of them too
Posted: Fri Sep 04, 2009 8:05 am
by brianwidahl
i heard the pro comp x-terrains are awsome
my buddy in calgary runs them on his h2 with a 6 inch lift.he swears by them
Posted: Fri Sep 11, 2009 9:05 am
by dwaxman1
12.5 do not rub at all...
