need help upgrading interior
- tattoo
i have a 95 h1 when i purchased it the console and dash parts were missing i have purchased a brand new dash pads front and rear consoles for a 2000 model ?? but having a problem lining up things and the vent hoses thanks in advance for any help
- brianwidahl
Re: need help upgrading interior
where you live?
i recommend e-mortal customs in calgary alberta
i have no idea how close that is for you sorry
brian
brian
[quote author=tattoo link=topic=1272.msg10872#msg10872 date=1251995637]
Sorry to tell you but you are going to need alot more than the dash pads. The HVAC systems are completely different for both those years, I would recommend getting the 98 and up upgraded HVAC then the vent hoses should line up. However you will still have an issue with the driver's side of the dash as there are many things that were part of the dash in 95 and not in 2000 and vice versa. This is not going to be an easy fit! Are you sure you can't get a 95 dash??? It would make your life way easier!!! Either way Good Luck!
- tattoo
i have the upgraded 97.5 hvac system already in the truck also i seen video on installing hvac ill see how much i rember when i start
GOOD LUCK....KEEP US POSTED AND PICS PLEASE .....BEFORE AND AFTER <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
