Anyone out there using the Cognito leveling kit or tie rods? I put on the Pitman and Idler arm support kit last weekend. Both the pitman and idler had to be replaced not that long ago and it seems to be a pretty common issue when running the bigger rubber.
The control arm leveling kit looks to make more technical sense then relying on just the torsion bars themselves. http://cognitomotorsports.com/store/page15.html
I'm starting to get a little wear in my tie rod ball joints so I figure I might as well go straight to an upgrade rather then replace them with stock.
Cognito Front End
- Canyonero
