Transfer case
1650shawn
Transfer case
Post by 1650shawn »
I'm going to Baltimore to pick up my 94 H1 next week.I will be driving back to Montreal with it.The owner advised me not to drive her over 55mph for long periods because the transfer will overheat.Should I be worried there is a problem with it or is  this normal for a 94?
NorthBayH1
Re: Transfer case
Post by NorthBayH1 »
I have heard that the vampire cooler was a real issue in eariler trucks the port would become blocked with some contaminates the cooler would stop flowing properly and the t-case would self destruct from the heat.  If it is an original t-case I would be aware and take it easy not push to hard.  I have blow 2 t-cases from serious wheeling if you do blow it I know where you can get a reman .Correct me if I'am wrong
98hmc4
Re: Transfer case
Post by 98hmc4 »
Ask if the previous owner has any service documents. If so see how old the oil in the t-case is. It might be worth switching to synthetic before you drive her home.
NorthBayH1
Re: Transfer case
[quote author=98hmc4 link=topic=1528.msg12512#msg12512 date=1265816163]
It would be wise to switch all the oils before you do traveling anyway
1650shawn
Re: Transfer case
Post by 1650shawn »
He is supposed give me all maintenance records.It will be sitting near Baltimore for a few weeks at my brothers place.I'll have him check for fluid changes and have him do the necessary ones.Wierd feeling owning a hummer and having to wait a month before I can drive it. <img src='http://www.canadianhummerclub.com/forum ... #>/sad.gif' class='bbc_emoticon' alt=':(' />
Thanks for the input.
98hmc4
Re: Transfer case
Post by 98hmc4 »
Enjoy the wait, it will make it that much better once it is in your drivway! <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' />
