New Lift Pump For An H1
98hmc4
Post by 98hmc4 »
Hi,
Does anyone know where I can get a heavy duty lift pump? I'm pretty sure mine is on it's way out. I would prefer to get it from Canada because I need it as soon as possible.
Thanks,
Martin
Re: New Lift Pump For An H1
[quote name='98hmc4' date='11 May 2010 - 05:54 AM' timestamp='1273575289' post='16730']
Hi,
Thanks,
Martin
pm ROY
[quote name='98hmc4' date='11 May 2010 - 06:54 AM' timestamp='1273575289' post='16730']
Hi,
Thanks,
Martin
Get a pump from your local parts guy, stock GM diesel pump is all you need.
If not, I do have a hd pump from Heath Diesel.
98hmc4
Post by 98hmc4 »
Thanks Guys,
I picked up a GM# 15754298 or ACDelco# EP1000. I did a little research and found that this pump is better than the stock one.
Martin
[quote name='98hmc4' date='11 May 2010 - 08:25 PM' timestamp='1273627528' post='16775']
Thanks Guys,
I picked up a GM# 15754298 or ACDelco# EP1000. I did a lottle research and found that this pump is better than the stock one.
Martin
post pics broooooooo <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
