calculator to see what happens to your speedometer reading when you change the size of your tires !!!
Tire Size Calculator
Change The Size Of Your Tires !
Re: Change The Size Of Your Tires !
Great post T.C...awesome information!!
- Tom
Once you get bigger tires, and your gearing figured out, send Travis a msg and he can get you a new DRAC to work with your configuration.
[quote name='Tom' date='01 June 2010 - 12:23 PM' timestamp='1275413001' post='17704']
<img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> G <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> GOOD INFO MERCI BROOOOOO <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
- JL
That's a good link TC BUT I can do you one better! Our vehicles are superior, and the tools we use should reflect that!! Miatas are tiny and wimpy, HUMMERS are big and tough!!!!
I've got for you a MAN'S tire calculator, a calculator that juggles chain saws..... A Calculator That Kicks Ass!! A Calculator For HUMMERS. (this is the only way to make a tire calculator tire sound exciting you see) I think this does a better job at letting you know what you really care about, which is how accurate your speedo is and how much clearance you're gaining! Honestly, WTF do I care about the radius of my tires in millimeters and some big black circle that tells me NOTHING?!?! Miata calculator FAILS the judgement of JL....
Screen shot shows what stock size tire was on my H3 and what I upgraded to. Plus mine looks much prettier. Send me a PM if you want to give it a try!
[center]
[center]
- Sugarphreak
That is pretty cool, now you have to make it a download-able EXE file!
The problem with that Miata one is the tire gets so big that it covers the calculation!!! lol!!
post the link brooooooooooooo...... <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
- Injunfarian
- CHC President
I made a calculator awhile back with various offroader tools including force calculator using BillaVista's formula etc...
http://fabbedin.ca/calc/
- shotgun-cam
problem is went from p265 to lt285
- Injunfarian
- CHC President
[quote name='shotgun-cam' date='23 June 2010 - 12:13 PM' timestamp='1277313219' post='18529']
Difference between P and LT is just the load rating etc. The numbers still mean the same thing(Width in MM/Ratio of Tire Rimsize.)
P = Passenger
LT = Light Truck
P = Passenger
LT = Light Truck
