Air Ride Conversion Warning Lights On Now
Canyonero
Re: Air Ride Conversion Warning Lights On Now
Post by Canyonero »
There shouldn't be any direct correlation between the ABS and the suspension. If I had to guess you maybe caught a wire or connector going to the ABS sensors during the install?
You can try to clear the code by disconnecting the battery for a minute.
The problem with socialism is that eventually you run out of other people's money.
