H2 Gas Problem
Re: H2 Gas Problem
how do you get it running??
Re: H2 Gas Problem
Start with your fuel pump relay and your fuel pump fuse...seen this before!
citiboy
Re: H2 Gas Problem
Post by citiboy »
They (GM) just changed my fuel pump control module. Under warranty of course Image Image
<div> </div>
Re: H2 Gas Problem
[quote name='Cláudio' date='28 June 2010 - 06:57 PM' timestamp='1277747861' post='18639']
I saw the P CMB fuse and F/PMP relay. It is ok.
Cláudio
start with those!!
