H3 Arb Snorkel Install
Do You have an H3???
THEN YOU NEED An ARB SAFARI SNORKEL!!!
You May say but you only Drive on the street...BUT YOU NEED AN ARB SAFARI SNORKEL!!
You say you do Some Off-roading then you need the Peace of Mind and Engine Protection that Comes For Having an ARB SAFARI SNORKEL!!
In other words, Now that YOU KNOW THAT YOU NEED AN ARB SAFARI SNORKEL!!! Here is how you install one on a 2007 Adventure Package H3!!
Re: H3 Arb Snorkel Install
What? no how to do???Is there a missing link?? <img src='http://www.canadianhummerclub.com/forum ... mellow.gif' class='bbc_emoticon' alt=':mellow:' />
[quote name='Roy' date='05 July 2010 - 01:00 PM' timestamp='1278331200' post='18862']
No, I lost power at home!!! Here is the full install!!!
Step 1:
Jack up and support the front of the vehicle and remove the pasenger front tire.
Step 2:
Remove the mudflap and the inner fender to allow access for the routing of the snorkel and for the mounting screws.
Step 3:
Remove the factory airbox and now you are ready for the installation of the Safari Snorkel.
Step 4:
Install the supplied ARB Template on the fender and make sure it is well secured with tape!Now drill out the holes and be sure to be exactly on the lines!! It is very important to cut exactly on the lines for proper fitment and placement!!! PS: Don't freak out you now have a HUGE hole in your Fender...but It will be worth it!!!
Step 5:
Now that the holes are cutout, place the snorkel and align it to the windshield and mark where you are to drill for the windshield bracket! Note: USE tape!! It makes it way easier to see where to drill!!
Step 6:
Verify Snorkel Placement BEFORE YOU DRILL ON THE WINDSHIELD PILLAR!!! Make sure that everything is where it is supposed to be!!! VERY IMPORTANT!!!
Step 7:
Now that you have drilled out the windshield pillar, remove the windshield trim and deburr the holes and seal them with silicone and install the supplied spacer so as not to kink the windshield trim when installing the snorkel support bracket! Make sure everything is lined up BEFORE you put the trim back on!!!
Step 8:
Now you are ready for final fitment. Remove all tape and templates and clean the areas well.
(Don't cry the holes in the fender are TOTALLY WORTH IT!!)
Step 9:
Now to the engine compartment. YOU MUST SEAL ALL CONNECTIONS WITH SILICONE TO ENSURE A WATERTIGHT SEAL!!
Step 10:
Don't forget the factory drain holes in the air box!!! Otherwise you will have an unwanted surprise!!!
Step 11:
Reinstall the factory airbox and use the supplied rubber hose to connect the factory airbox to the snorkel body.
Step 12:
Install the Intake ram on top of the snorkel and then check and recheck all connections!!! Remember YOUR ENGINE depends on a Water Tight Seal!!!
Reinstall the inner fender and the tire and take it off the jacks. Then...
Stand Back and Enjoy the New Look of Your H3!!!
Now that it is all installed...take it for a roadtest and enjoy the new found power and improved mileage from a True Ram Air and Cold Air Intake system!!
If you would like the same kit installed on Your H3 why not PM and I can do the same for you!!!
Enjoy!
now that looks great wowwwwwwwwwwwwwwwwwwwwwwww.......great info step by step thanks Kevin . Can I use this info for my new website!!!!!maybe you tube next time!!!!!!!
duncanpa
Post by duncanpa »
[quote name='T.C.' date='05 July 2010 - 02:21 PM' timestamp='1278357678' post='18890']
Hey, TC....what new website??
[quote name='duncanpa' date='05 July 2010 - 02:56 PM' timestamp='1278359815' post='18891']
I am work on new website for ARB for Canada....should be up and running for end of year!
Great job Kevin did on the H3 it look hot!!!!! what do you think? what does everybody think of the H3 with a Snorkel
