Just thought I would share some advice that I found out the hard way....
I own a 2008 H2 and on our last trail run, I had my differential carriage bolt fail. I believe that is the name of it. It is on the passenger side of the differential, on the top right before where the drive shaft attaches.
Now this is not a bolt that should ever fail but yet mine did causing the differential to drop and the resulting change in angle caused the drive shaft to litterally explode!
I am not sure if this is the same on the 07 and older models, Kevin may be able to shed some lite on that, but I would advise everyone with an 08 or newer to inspect this bolt, and may not be a bad idea to replace it. Mine may have been a total fluke but I question the quality of the bolt that was in there originally. I have since installed the beefiest tempered bolt I could find to ensure this never happens again.
I took apicture but unfortunately I can't upload it due to being at my maximum upload data restriction
