Drawer Units or bed slide for H1`s
any members have intrest in this item ...maybe a groupe buy....I want to add one to my H1 open top ...any ideas out there
- Archngel
Re: Drawer Units or bed slide for H1`s
Ive been looking for 1 sectionnal drawer unit 8 inch high for my H3 or even a slider, but didnt find anything not even on the net for H3, I am about to build one custom 41" wide, 23" deep and 8 or 9 " high. with a top plate that slide forward to go over the back seat to mak efloor more level. Just have to find a aluminium welder to do it in diamond plate and find the diamond plate. it would be detachable if I dont need it and easy install when needed. KEVEN ,can you weld aliminium plates??
Mainwhile,, concept unit in HDFB (high density fiber board) is in progress. So ill be able to store tools, straps, and other without taking floor space in cargo.
- Archngel
Once done ill post some,, now Im at puzzle stage,, pieces cut out ,, need fitting, assembling, and painting.
good luck ..can't wait to see what you did <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
where is this one?? would love to see these....
