Mini Steps for Rocker Panel Protector H3
Archngel
Post by Archngel »
Hi!
Has anyone as or know someone that has a set of mini step made to fit the rocker panel protector for the H3.
Im looking for pictures of the item, top and bottom as well as dimention. Want to compare the under part with the full running board, to see if the bracket would be compatible. I know that they seems to be portion of the long running board. Need to confirm.
If anyone can help me on this it will be greatly apreciated.
thx
Marc
Archngel
Re: Mini Steps for Rocker Panel Protector H3
Post by Archngel »
Thx to every one that emailed me infos regarding this,,
Got the mini step, switched the brackets to my existing running board and installed it. I now have a removable long running board. in five min I can be off road fonctionnal, Leave the running board at home or strapepd on the roof and once fun done,, back to normal with running board <img src='http://www.canadianhummerclub.com/forum ... >/wink.gif' class='bbc_emoticon' alt=';)' />
M.
