5-way 3-position switch - $35
various fittings & hose - about $35-40 ish
In-cab three way switch to control the solenoid - $10
Now to just get a proper bracket made up for the manifold, and to add a safety release valve (like the one on the manifold) between the pump and the solenoids. I built this system with a couple levels of redundancy, the safety release valve will expel air if it sees anything over 150 psi (which Im doubting the pump could even get that high), the guage is good to 200 psi, and the hose is good to 300 psi (or how well my fittings hold up).
I guess it really boils down to having liked the older style CTIS Aux setup (which was closer routed to that same cutout, but was unable to isolate its output), and also not wanting to always have to open my hood to help someone with a flat tire, etc. I will admit Im kinda a gadget/gismo junkie as well, which played a role in this project. I know not everyone will approve, but what do you think?
