Just want you guys to keep Dec. 11th open for a Winter Mud run at a Top Secret Location that I will unveil shortly! The water and the mud is already really deep and the obstacles are great! It is a very technical area with lots of tight sections but LOADS of fun!!
So Are You Interested?<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' /> Then Stay Tuned More Info will follow as it becomes available!!!
Hope to see you there!!!
QUEBEC CHAPTER WINTER MUD RUN!
- duncanpa
Re: QUEBEC CHAPTER WINTER MUD RUN!
[quote name='Polar Bear' timestamp='1289097989' post='22597']
Hmmmm...let me guess...winch and nerves of steel required!!!!!
[quote name='duncanpa' timestamp='1289142649' post='22608']
Actually you might be able to get by without winching but not likely...I even have several parts that I have no choice but to winch out/over. There is alot of twist ditches aka 3 wheeling and 2 wheeling.
To say you need nerves of steel...not this time...it is a very safe area that has no drop offs aka 'cliffs' but alot of rock and deep water and mud and tight turns in between big trees and rocks!!
It should be really fun with some snow! It will be even muddier and deeper!!!
[quote name='Polar Bear' timestamp='1289243822' post='22655']
I'M IN <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
[quote name='T.C.' timestamp='1289253011' post='22673']
Are you sure? From what I heard, your truck is enjoying the spa trips and does not what to go off roading.
Nice warm place to stay in, NoNo fudge all day long!Mmmmm And a full body rub to boot.
Now tell me why any thing would leave that enviroment to be "abused" and put away dirty in cold storage! <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
[quote name='dwaxman1' timestamp='1289959533' post='22869']
are you going Roy??
Not sure. hmmm does not seem tooo challenging for me.May have to take the city princess to make it a little more challenging!! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
are you going Roy??
[quote name='Roy' timestamp='1289957767' post='22868']
<img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> ...are you coming down or do I OUR HUMMER
- Archngel
Sound interresting although ill be on winter tire, which I dont think that they are very good off road Yokohama geolander are great on ice, medium/high in snow, but off road,, hummm, So if I have someone to winch in front and back in case of need, will try it. Got rocker protector, under body armor so will get muddy <img src='http://www.canadianhummerclub.com/forum ... /smile.gif' class='bbc_emoticon' alt=':)' />
GOGOGO <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Awaiting further detail on this event
Ok here is a ton more info!!!
The Top Secret Location is my property in Franklin Center, Quebec!
It is SUPER Tight...why...because I made it that way!!!
I was on the backhoe today digging some sections even deeper than they naturally where!! My Can-Am Outlander 800 MAX XT almost disappears into some of them and I have had to winch out of several of them due to the exit angle!! Like Straight Up!!!
Are these trails anything like what we do near Weir...not in any way...there is alot of rocks in between trees and some serious side angles and some deep mud in between trees with logs buried at angles underneath!! So there is no way you can go straight thru...the logs kinda track you to the side and really don't allow forward motion...but they direct you to some challenging obstacles.
Many of my trails kinda look like a snake trail since they double back on themselves and have tight 150-180 degree turns in between trees and rocks.
I have cut almost every branch that could scratch or damage a vehicle and I have cut many trees that made it just too tight but left some big ones for us to squish our way thru...well it will be really tight for H1s and kinda tight for H2s but it will be spacious for H3s...well sorta!! <img src='http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt=':rolleyes:' />
I do have some really really deep water for anyone daring enough to try and some really long water crossings. I also have a mud bog setup...but I doubt that once you go in anyone will come out!!! I have only managed it once!!! Every Other time I had to winch out or pull it out with my backhoe!! Still super fun though!!
I was wondering if anyone would like to come and help a bit with tree cutting on Nov. 27th and/or Dec. 4th, I have alot more trail to open before the 11th!! Any takers??? Any Takers with chainsaws???
Let Me know!!!
And Roy I would still recommend the bush truck...'The Princess' doesn't deserve this kind-of treatment!!
And TC tell Alain to come too!!
For Sleeping Info here is the Bed and Breakfast 1/2km away!!!
http://www.bagnell-hall.com/
Let Me Know Guys!!!
Hope to See You there!!
Btw, once we get this all done we will have a place to play ALL WINTER WHENEVER WE WANT!!!! Yiipppeee!!! No More waiting till spring/summer!!! Yiiippppeeee!!!
Let Me know!!!
Let Me Know Guys!!!
