95 gasser 3" body lift
lazydayhummer
Post by lazydayhummer »
Can anyone give me any pointers before I start tearing into the job of putting my 3" bodylift on my 1995 gasser? Has anyone done one before? Thanks ahead of time people <img src='http://www.canadianhummerclub.com/forum ... /smile.gif' class='bbc_emoticon' alt=':)' />
Re: 95 gasser 3" body lift
[quote name='lazydayhummer' timestamp='1295716144' post='24426']
From what I've been told, anything over 2" you have to watch the steering column slide,dual tank have to watch out for the crossover valve(diesels
),the cutout for the column may exceed the rubber covering.Air lift hooks would be welded on a angle and not straight
I'm sure there is more to learn.
Darcy
Post by Darcy »
you must undo your gas tank straps and put spacers between the tank and body
you will need longer tank straps as well
is this a homemade kit
you will have to notch out where the steering column goes threw
watch your filler neck as well anything over 2 inch you may run into problems
