Lift Kit
- Cookie
Re: Lift Kit
If I'm not mistaken, you should be able to simply adjust the torsion bars up 1.25". THe H3 came with 33" tires as an option (adventure pkg) 285/75R16. You can also check out ridge demon for H3 Alpha torsion bars. Hope this helps!
J
J
- SADA
Re: Lift Kit
[quote name='Cookie' timestamp='1297738285' post='25153']
J
Thanks Cookie, if only adjust the torsion bars do I stil need a front end alignment after or not?
J
