Warn winch rebuilding
Tom
Post by Tom »
Just wanted to share some photos of my rebuild of 3 Warn M12000 winches.
The hardest/worst part is the gear case, all 3 contained water and mud combined with grease. A absolute mess to clean.
Because these winches spent most of their life on the front of a truck that has been driven in the winter, they are badly pitted and corroded.
Two of the winches are 2003, and the third I would say is a 1996 (I have only partly pulled apart the 1996)
Kind of condition/corrosion:
Parts sandblasted:
Gears washed and re-greased:
Painting:
Fresh Paint Job/Rebuilt motor:
Drums Machined:
New Gaskets:
All Assembled:
New Seals:
Drums Painted:
All Finished (minus the electrical)
Still putting in together.. have a box of new bushings.
Re: Warn winch rebuilding
They look brand NEW!!!
Nice Work Tom
what did you do with the drum?sandblast?
Tom
Post by Tom »
[quote name='T.C.' timestamp='1300280387' post='25930']
Working on that right now. It has a couple of machined surfaces that can't be sandblasted as they need to be within a a certain tolerance. I think I will take them to a buddy's machine shop so he can machine them on his lathe. Will see what he says and I will keep you updated!
Tom
Post by Tom »
Updated! More pictures added!
VERY GOOD POST TOM THANKS FOR THE INFO <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
looking good... mine will be your next one on your bench.... wink wink nudge nudgeImage
and if you are bored, you can do my H2 WARN as well...Image
Tom
Post by Tom »
[quote name='dwaxman1' timestamp='1300601448' post='26038']
Ya, that's right. I did these because I am bored!
Thanks TOM, you are Great..Image
tylerlisk
Post by tylerlisk »
Just finished rebuilding my Warn winch as well! Anyone need any help let me know, I can set you up! The warn winch is actually a very simple system and not hard to repair. I also got a new motor for 70 bucks and it works perfect!!!
