This 1987 humvee belongs to a gentleman in kitchener i recently took on this project to do a cummins swap exept this time its a 24 valve cummins with a built dodge tranny and cast iron transfer case with 2wd and 4wd option
she is stripped to the frame and needs all the suspension and halfshsfts replaced
the truck is currently 24v but will be rewiring everything to 12v
will post pics as i go on this swap as well
HUMVEE CUMMINS SWAP
- Darcy
HUMVEE CUMMINS SWAP
- Hesh
Re: HUMVEE CUMMINS SWAP
Mind if I ask what you charge for a Cummins swap? What tranny do you put behind it? Do you provide the motor, trans and tc?
Cant wait to see it, love the HMMWV's
- Darcy
I have a thread of the white one i built last winter if you want to check out under the h1 section
as for price it can vary if you want to put a used engine or new or how much of the drivetrain you want to rebuild
my last one was 10k in parts alone using the 4l80e tranny but all upgraded billet components as well as tc
im going to be using dodges 47 re tranny with billet tc ive done a duramax swap this will be my second cummins
havent really came up with a figure cause every truck has needed different extent of repair with ripped apart
you can bet a good 10k to 15k for a swap if done rigtht !!!
- johnnyspikesH3
Still a good price . For the main 2 words there . DONE RIGHT ! <img src='http://www.canadianhummerclub.com/forum ... n_cool.gif' class='bbc_emoticon' alt='
- HummerBro
Gotta get it done right and I'll be super excited.
Long Island Used Cars Car Loans NY NY Used Cars Sell a Car for Cash MI Used Cars MI Dealers NJ Used Cars Michigan GMC Dealers Michigan Buick Dealers Michigan Used Cars
NYC used cars Sell Your Car NY Smithtown Area Audi Huntington Area Audi NY Volkswagen New York Volkswagen Toyota certified used cars
- 03H2
i am looking for someone to do this to my H2, i surf Pretators web site alot drooling over the duramax conversions on there steady but NO prices.
- Darcy
Im a little tied up at the moment I have this humvee to finish and another suburban to convert to duramax than I will be experimenting doing a H2 duramax probly do one first than possibly offer it as a swap
- 03H2
or it would it be cheaper for me to drive out there and buy your black H1 off you instead..... <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' /> ROAD TRIP!!!!..wife would look good driving her car for the winter anyways..
- Darcy
heres a few updated shots on the humvee 24 valve build
-fabricated some custom mounts again but stronger than mine lol !! using the stock hummer engine mounts for future if ever needing to be replaced
-and I did make extras for future swaps <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
-so I have a built 2003 24 valve cummins transmission is the 47 re billet torque converter and inside components all upgraded as well
-1 ton transfer case with selectable 2wd and 4wd
-had to get rear driveshaft shortened and front driveshaft made longer hanger bearing was lowered half inch for clearance issues
-have pics of the left and rigth mount
-turbo has arrived but waiting on adapter going with a T4 HX 40 turbo with wastegate and will be 5 inch exhaust turbo back
-more pics to come as build goes on
- 3dinnovations
When my 6.5 dies, I'm certainly bringing my H1 to you for a swap! Great WORK <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Ride Hard!
