Hi,
I have 'no driver side window and no power locks', on my H3
What I can do <img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />
Thanks
H3, no driver side window and no power locks
- quochuydoan
- victan
Re: H3, no driver side window and no power locks
Well, I suppose you have checked already the fuses/
So, most probably a computer problem or electrical pb....<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />?
See a GM dealer, might be the best .
Not exactly helpful... I know <img src='http://www.canadianhummerclub.com/forum ... ey-013.gif' class='bbc_emoticon' alt=':wtf:' />
- Archngel
it is electrical have you checked the wiring in the conduit between body and door maybe a kinked wire is broken.
Can the other doors be locked from the driver side master switch, if not, maybe the switch panel in the door armrest is defective.
Maybe Keven (Polar Bear) can spot the trouble quicker. just stating the obvious. in 6 yrs, and after 3 H3,I never encounter that problem.
- quochuydoan
I will check the fuses and disconnect the battery for few minutes .
This problem was happenned when I have the low battery discharge ...
Thanks
Thanks
- quochuydoan
Hi,
IT WORKS NOW !!!
How to have an issue?
1) I verify and pull out and put back fuse #8 and circuit breaker/relay #68 (d'ont works)
2) I try to disconnect battery and leave it off for 60 minutes before put cable back on (d'ont (d'ont works))
3) I unsnap switch panel from drive's door, disconnect and reconnect this switch panel, WITH THE IGNITION ON, and it works !
NOTE: this problem was particularly happen, after the battery has been run down and I try to start H3 in many times.
Thanks you for yours helps and Keven too.
IT WORKS NOW !!!
