Hi,
I have 'no driver side window and no power locks', on my H3
What I can do ?
Thanks
H3, no driver side window and no power locks ?
- quochuydoan
Re: H3, no driver side window and no power locks ?
Start by checking your fuses and also check the wiring harness in the door, you could have a broken or pinched power wire.
- quochuydoan
Hi,
IT WORKS NOW !!!
How to have an issue?
1) I verify and pull out and put back fuse #8 and circuit breaker/relay #68 (d'ont works)
2) I try to disconnect battery and leave it off for 60 minutes before put cable back on (d'ont (d'ont works))
3) I unsnap switch panel from drive's door, disconnect and reconnect this switch panel, WITH THE IGNITION ON, and it works !
NOTE: this problem was particularly happen, after the battery has been run down and I try to start H3 in many times.
Thanks you for yours helps and Keven too.
IT WORKS NOW !!!
- johnnyspikesH3
That was the BEST french Happy reply speech ever ! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> QUOC you are officially my hero for 1 day . Please post more <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt='
' /> Viva Le Quebec !!!
Last edited by johnnyspikesH3 on Thu Dec 01, 2011 3:37 am, edited 1 time in total.
great teamwork and thanks for keeping us up to date.. it is always best when we talk about the issues and what worked to resolve them.. help other member see the value and save them a little $$$
- shotgun-cam
Note on H3's if power levels drop below certain level all power locks and windows will stop working till battery levels rise. You have to use key on drivers door to open truck then hood and either recharge battery or try and start truck. had it happen with Rhino when aux lights were left on.
- SELWA
I'm having the same issue now... Will try removing the door panel and re-connecting again. Tried all the other stuff as well and still nothing. Too dark outside to try it now. <img src='http://www.canadianhummerclub.com/forum ... t-argh.gif' class='bbc_emoticon' alt=':argh:' />
1995 H1 Wagon SOLD!
2007 H3
2007 H3
- SELWA
Ok back to normal now. I tried everthing posted here and this is what did the trick. I removed the keypad from the door, took it apart and plugged the PC board back in. I used a screwdriver to touch the black contacts and within a few seconds the door locks were working again!!! <img src='http://www.canadianhummerclub.com/forum ... Rockon.gif' class='bbc_emoticon' alt=':rockon:' /> Total cost $0.00
1995 H1 Wagon SOLD!
2007 H3
2007 H3
- shotgun-cam
Selwa get some contact cleaner try A1 components at north queen
