Awesome HUMMER H3
Post your Pics and Videos here.
SwaggBoss
Awesome HUMMER H3
Post by SwaggBoss »
Re: Awesome HUMMER H3
Meet the BLACK RHINO
What dosen't show 4way alternating flashers ,Lumin's HID headlamps , 3 bell Trux TRain horns, and winch swapped out for a 10,500lb synth rope winch. Come to the Toronto gathering in May and meet the Rhino.
P.S. our xmas card
SwaggBoss
Post by SwaggBoss »
[quote name='shotgun-cam' timestamp='1325982480' post='34281']
P.S. our xmas card
WHAT AN AWESOMW TRUCK!!!! ImageImageImage
I AM IN LOVE WITH YOUR H3!!!
I am planning to do something similar....
The air-compressor on the top is it only for the air/train horn or do you use it to inflate your tires?
Air horns are supplied by the 11 gallon resevoir tank (yellow cylinder) and is repressured by a compressor that is carried on board. Yes tank holds air at 125psi and has reinflated the tires.
For bumper talk to TC as well the snorkle is from him. the new winch is from roys aka crazy canucks 4x4.
SwaggBoss
Post by SwaggBoss »
COOL! Thanks for the info! ;-D
Almost forgot when ARB bumper and winch installed two more parts are required/recommended. The ARB foglight set ( remove back screws and coat with anti-sieze and reinstall makes lamp replacement less of a hassel) and a lift or leveling kit ( ours has a Superlift levelit kit have shop install and do an alignment). If you don't the truck will hunt gophers (nose down) and loose its foglamps.
Also Rhino is an 08 H3 ALPHA meaning it has the 5.3 litre v8 at 300 hp and 300 f/lbs of torque. this allows it to run on top of mud see Oct 2 nd Fall colours run.
SwaggBoss
Post by SwaggBoss »
[quote name='shotgun-cam' timestamp='1326253460' post='34374']
Oh, Thanks!
