2004 H1 Diesel
AmpGramp
2004 H1 Diesel
Post by AmpGramp »
Best in the New Yeat to all.
Going to change my engine and thinking of buying a new one rather than rebuilding my old one.
My transfercase, transmission and radiator are new and the rest of the vehicle i9s in good shape.
Any suggestions for add on's. Improve milage,two wheel to four wheel drive, trans mission coolers ect ect.
Bob Fitz
Hesh
Re: 2004 H1 Diesel
Post by Hesh »
What is wrong with the current motor?
AmpGramp
Re: 2004 H1 Diesel
Post by AmpGramp »
[quote name='Hesh' timestamp='1326955599' post='34525']
Rad problems, over heated.
Toyed with conversion but leaning towards replacing with same type. Cheaper and with extra cash want to throw some extra improvements at it.
Bob Fitz
paulg
Re: 2004 H1 Diesel
Post by paulg »
if you are going to swap it with another 6.5L you should look at the P400 series motor from GEP, a lot of improvements etc and most of the accessories from your current motor will swap over.
Big thing to make sure of when shopping for a new motor is that it will accept a center mount Turbo, the 6.5L blocks from the pickup trucks are designed for side mount turbos.
[left]2001 black HMCS
3" bodylift
Heath Programed ECU
Remote PMD
CMGS water\meth injection
Rear head cooling kit
Scangage II
Boost, EGT, Temp gauges.
Dynamat extreme
dual optima red tops
Straight piped exhaust[/left]
AmpGramp
Re: 2004 H1 Diesel
Post by AmpGramp »
[quote name='paulg' timestamp='1327001275' post='34538']
Thanks for the Info. Who is GEP ?
Bob Fitz
Hesh
Re: 2004 H1 Diesel
Post by Hesh »
AmpGramp
Re: 2004 H1 Diesel
Post by AmpGramp »
[quote name='Hesh' timestamp='1327031739' post='34549']
http://www.optimizer6500.com/
[/quote].
Interesting stuff, nice to have a site like this
Where would I inquire about availablty and cost?
Bob Fitz
Re: 2004 H1 Diesel
AM General owns GEP..
Re: 2004 H1 Diesel
Check on warranty's, if you can get a 5 yr warranty go for it, Most rebuilders give 1 yr limited. With any conversion, you loose something, <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' />
