engine repair
- 98hmc4
Re: engine repair
Not sure about the gaskets but you might want to do a head cooling kit while you are working on the engine. It reduces the high heat build up on the rear of the engine.
- 98hmc4
Re: engine repair
I have read about a few people who have added the extra cooling lines in NA engines to prevent having problems. They now have 169 000 miles and couting with no problems.
- 98hmc4
Re: engine repair
Just thought while he is repairing the heads it would be a good upgrade. He is able to do very easily with his truck apart.
- 98hmc4
Re: engine repair
Flashoffroad sells them as well. <DIV> </DIV><DIV><a href="http://www.flashoffroad.com/Diesel/Rear ... ooling.htm" target="_blank">http://www.flashoffroad.com/Diesel/Rear ... </DIV><DIV> </DIV><DIV>This kit is very similar to the one that crebbin has. They have instructions on this link so you know what you need to do.</DIV><DIV> </DIV><DIV><a href="http://www.heathdiesel.com/P/HDP1551/" target="_blank">http://www.heathdiesel.com/P/HDP1551/</A></DIV><DIV> </DIV><DIV>This one is more expensive but might do a slight better job. I have seen it for $650-$825</DIV><DIV> </DIV><DIV>Off topic-Matt will you sell one of your seats? If not how much would you want for both?</DIV><edited><editID>98hmc4</editID><editDate>2008-02-13 20:28:05</editDate></edited>
