What Mods Have you Done?
Injunfarian
CHC President
Post by Injunfarian »
Hey just wondering what kind of mods have been done to canadian hummers.<DIV> </DIV><DIV>Mods Done by previous Owner(s):</DIV><DIV>Stinger HD Brushguard</DIV><DIV>PIAA Lamps</DIV><DIV>Airhorns</DIV><DIV>Momo Steering Wheel</DIV><DIV> </DIV><DIV>Mods Done by myself:</DIV><DIV>LED Clearance Lights(Turn Signal and Tail Lights coming soon!)</DIV><DIV>CalGold Slantback(Hardtop)</DIV><DIV>2" Suspension Lift</DIV><DIV>SMA Style Hood Snubbers</DIV><DIV>1/4" Wheel Spacers</DIV><DIV>M-Type Connector on the CTIS Pump</DIV><DIV> </DIV><DIV>Future Mods:</DIV><DIV>Duramax Conversion</DIV><DIV>2" Body Lift</DIV><DIV>42" Swampers</DIV><DIV>Front Differential Centering Kit</DIV><DIV>Lockers</DIV><DIV>Rock Ram</DIV><DIV>Aluminum Rad</DIV><DIV>Rear Winch</DIV><DIV>Airbag Suspension</DIV><DIV>4wheel steering</DIV><DIV>overhead console/sound system</DIV><DIV>switch panel</DIV><DIV>cb with mil type attenna</DIV><DIV>gps</DIV><DIV>sound insulation</DIV><DIV> </DIV>
Injunfarian
CHC President
Re: What Mods Have you Done?
[QUOTE=mudhog]
-Centimatic Wheel Balancers
-SOL-D (remote mounted PMD/FSD)
-Knee Panel for Front Passenger
-Hour Meter Kit
-Air Filter Restriction Gauge Kit
[/QUOTE] <DIV> </DIV><DIV>definately some things I would like to do</DIV><DIV>also what does -Steer Gear Box Fourth Hole Mounting Tab do for you? and did you notice much difference with the wheel balancers?</DIV>
Injunfarian
CHC President
<P>Thanks, and yes I have seen the reenforcement kits and do plan on getting them when the time(err money) is right.</P>
Injunfarian
CHC President
Very nice, as soon as spring comes I plan on adding high idle switches and putting them in place of my driverside ashtray since its not in use nor ever will be.
Injunfarian
CHC President
[QUOTE=mudhog]Just added a near future upgrade of the 1999 style windshield washer
reservoir to my list...
This will also clear the old location for my hour meter and air filter restriction
gauge bracket..
[/QUOTE] <DIV> </DIV><DIV>be great if you take notes and share them with us. Sounds like a good mod and I might be interested in doing.</DIV>
