Magnaflow in and ordered extended bump stops .
- johnnyspikesH3
So the other day i did the Magnaflow . Very noticeable difference i have to say . I just ordered the Trail Duty extended bump stops 1/2 Inch for the H3 AFTER a lift . Get rid of nose bounce and dive during breaking . It also is supposed to have better handling . Will let you know the difference . Also as some of my friends know i will be doing a comparison once and for all between cranked torsion lift and a kit . I will get my Rough Country lift tomorrow . This kit is a spacer (front) Shackle rear system . Using your existing Keys . I will not be able to get it for a couple of weeks . So stand by and we can see what is better !!!!! Anybody H3 - H3-T GUYS LOOKING FOR THE BUMP STOPS ?? Trail duty is where you get them . $49.99 . Rough Country lift $69.95 . Of course there Tax, shipping , duty blah blah blah . http://www.youtube.com/watch?feature=pl ... d8LrtJNieQ
Last edited by johnnyspikesH3 on Tue May 01, 2012 10:08 pm, edited 1 time in total.
- Archngel
Re: Magnaflow in and ordered extended bump stops .
Looks very good I bet sounds veeery good too. <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
