Front end/Steering Components Q
Big_Dub
Post by Big_Dub »
I need to replace my inner tie rods, pitman arm, and idler arm. Does anyone have a good line on well priced parts? Don't know if this is available but was wondering is the whole assembly available to buy aftermarket? All input is appreciated. Than you in advance <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
thedub
Re: Front end/Steering Components Q
Post by thedub »
check with JBeetie, he just did the whole lot on mine..
[center]Yellow H2
Mississauga, Ontario.
(try that in your prius)
johnnyspikesH3
Post by johnnyspikesH3 »
[quote name='Big_Dub' timestamp='1337100636' post='37159']
Lots of places to find that at a great price . http://www.ebay.ca/itm/BALL-JOINT-TIE-R ... 1c2708a142 Also there is heavy duty Off road style made . Can't remember the name . Maybe KEV , DWAXMAN , or The West Coast guys know the name of the company that makes them . The tie rods are like baseball bat's .
Last edited by johnnyspikesH3 on Tue May 15, 2012 3:57 pm, edited 1 time in total.
03H2
Post by 03H2 »
Here is a couple sites that have some good HD tie rods and some front end kits.
http://dmaxstore.com/index.php?main_pag ... cts_id=479
And these guys,
http://www.rubberduck4x4.com/store/pc/H ... s-c162.htm
I haven't dealt with the 1st link guys to much but I did ask them a few questions and they were very helpful and knowledgeable about hummers.
s0ulst3al3r
Post by s0ulst3al3r »
I have kryptonite tie rods from Dmaxstore and I'm very happy with them ..also check into getting the cognito support kit for pitman/idler , since I've installed that kit I've never had any issue's
2005 H2 SUT - 2007 Chopper
Khamul
Post by Khamul »
I can give my 2 cents as I've done it all...
The cogito support kits for the pitman/idler are an absolute must! Do not get the tie rods though as mine failed in less than a year and a year and a half later, I still have yet to see them honour the lifetime warranty.... Complete joke!
Tie rods are a very debatable subject. Gaza's rods are awesome, I love my fabtechs.... However the knuckles and inner joint are the same as stock.... Which are the parts that fail.... The knuckle and the inner thus it does not make sense to change this unless you get a substantial lift kit (6" or more) as it's very unlikely the rod itself will ever break... I have a 2.5" lift on my front and I noticed recently that the tie rods boot rubs on the sway bar.
So if you MUST change your tie rods.... Go with kryptonite which G has, as the bar is a bit thinner than the Fabtechs. I will go with these if my fabtechs ever fail as I do prefer to have the bars beefed up as we go through some nasty terrain at times...
Big_Dub
Post by Big_Dub »
Thanks so much for all of the input guys! Now its just a matter of saving some $ for the parts. I think I'm going to go with the kryptonite kit and cognito supports. Just going to have to spend the money and do this thing right.
