2003 H2 front diff leak
amapsla
Post by amapsla »
Is it difficult to take apart and reseal the front diff on a 2003 Hummer H2?
Re: 2003 H2 front diff leak
[quote name='amapsla' timestamp='1339960196' post='37900']
First what do you need to reseal? Axle shaft or main housing?
If axles shaft seals need to be done, they can be changed with the differential in the truck.
If the case needs to be resealed you need to remove the differential from the truck and split the case, both tasks are relatively straight forward for someone with good mechanical ability!
Hope this helps,
