hey guys
just lately ive been having an intermittent problem of my doors not unlocking with the key fob.
new batteries in the fob
lock will always work and unlock is intermittent
on a side note
the odd time my driver door will have no power at all no windows, locks or heated seats. not sure why nothing has been touched in there. not sure if these are linked
the fob prob is all the time and the door power problem is say every second day
please help
its very frustrating
h2 door prob
- normsadler
Re: h2 door prob
When my seats weren't working it turned out to be a problem with the connection beneath the drivers front seat. I took the connector apart and the main power wires had melted in the connector. I removed them from the connector and joined them securely outside of the ligh plastic housing. No issues since then!
Norm & Sue
2010 White H3T (sold)
- Gadgets
Re: h2 door prob
[quote name='Tanky' timestamp='1340894174' post='38474']
Norm did you remove your seat to do this, our did you come up with some trick to get under there. My drivers seats heater doesn't work more then it works, and I'd like to inspect those connections under there.
<p class="bbc_center">
- normsadler
Re: h2 door prob
you can see the connector by looking in from the drivers side rear door, at least in my 2004. There should be a split in the carpet and a plug about 3cm square with a lot of small wires and 4 larger wires going into it. Just follow the wires from the seat down to the floor.
Norm & Sue
- brianwidahl
Re: h2 door prob
as far as i know the seat still work. but i cant recall trying it.
ill look into this plug under the seat when it starts acting up again.
the last few days have been fine so its very intermittent
thanks guys
thanks guys
