H2 steering wheel switch replacement
Has anyone changed the switches on their steering wheel? Is it painful?
- MasterMechanic
Re: H2 steering wheel switch replacement
very easy install but the steering wheel has to be removed to perform this. i would be happy to show you the procedure.
<p class="bbc_center">
- duncanpa
Easy he says right after he says the steering wheel has to come off.....gotta love the Hummer Tech's .... to them everything is easy (well, except for replacing the broken bolts on the exhaust manifold...apparently that's NOT so easy...!!!!) Have you ever seen a mechanic sitting in the engine compartment?<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />
