Im installing a boost and fuel pressure gauge in my H2 and I need to find a good place to tie in for power and lights off the ignition.
Anyone have a good wire close to the drivers side dash that will work for this?
where is a good place to tie in for gauge install
- hustler
Re: where is a good place to tie in for gauge install
[quote name='hustler' timestamp='1350001144' post='40509']
Look under your dash near the floor on the driver side. You have a junction box with several fused ignition power circuits. This box is normally where the vehicle accessories are plugged, so it is a safe place to tie in. If you wanted to be super slick you could even get the exact GM pigtail and then you would have a perfect connection!
