For Sale 2" Wheel Spacers
SELL Spare parts, OEM, After Market, what ever that is Hummer related and for your Trucks
citiboy
Post by citiboy »
Hi, I'm selling a set of 4 2" wheel spacers.
Here's the specs:
Construction: 6061 T6 Grade Billet Aluminum
Quantity: 4 Billet Wheels Adapters
Vehicle Bolt Pattern: 8x165.1mm or 8x6.5"
Wheel Bolt Pattern: 8x165.1mm or 8x6.5"
Thickness: 2" or 50.8mm
Center Bore: 130mm
Stud Thread Size: 14MMx1.50
I painted the sides with Duplicolor bed liner black but can easily remove. I only test fitted it on my Hummer H2 and i basically needed only 1". I'm asking $200.00. Buyers pays for the actual shipping.
Thanks for looking.
<div> </div>
Re: For Sale 2" Wheel Spacers
Jimmy, if you try and put 1" spacers on, will the studs not stick out past the adapter?? --from the spindle. I believe 1.5" is the minimum needed.
You can always ship to me , then I can machine these to the thickness you require. <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
citiboy
Post by citiboy »
Roy, the rockstar wheels have enough indentation to fit the 1/4" that will stick out from the studs with 1" spacers, i measured it twice....if it doesn't sell, then i'll ship it to you and shave half of it's thickness.
<div> </div>
citiboy
Post by citiboy »
SOLD!!!
<div> </div>
