Hey guys
i had a short in the right side tail lamp assembly. when i opened and replaced the bulbs the bottom socket was working and the upper light wouldn't work. so it was the light socker wire. i got new wire but i cant get into the rear panal from the inside to remove it and install the new one. any one have a guide on how to remove the inner trunk panal on the right so i can replace that burned socket wire assembly??
thank you.
