oil change
f1ipX
oil change
Post by f1ipX »
hello Hummer Peepz,
how much it will cost me to get transmission and differential oil change from stealership?
my fuse control box ( as they said it was corroded) was replaced by the dealer and cost me 770.00 thats with discount.
thanks in advance, f1
Re: oil change
On fuse box go to GM if its a newer truck ( they had some issues with cracked fuse boxes and corroded wiring (heater control wiring) for tranny diff or transfer case find an AC Delco approved private shop about 90 bucks each from our private shop. For engine oil go to dealer they under charge as a loss leader.
Also on tranny we used to have its oil pan dropped and internal filter changed and oil manually checked for large pieces cost is a little more but saved one tranny.
f1ipX
Re: oil change
Post by f1ipX »
[quote name='shotgun-cam' timestamp='1352011748' post='40792']
thanks Mr Shotgun,
i had used MOTUL
8100 Eco-clean+ 5W30 for my engine oil, im just trying to get my trans and front diff or transfer case done too.
one more question where can i find this private shop of yours?
thanks J
